It is currently Tue Dec 30, 2025 12:57 am
PostPosted: Fri Nov 09, 2007 2:26 am
Hi everyone,
My 1960 225 /6 makes a prominent "ticking" noise when I accelerate or start hill climbs. The previous owner said that this was typical and I put it down to spark/distributor noises, but I am beginning to wonder if the engine is knocking/pinging?
It does not appear to affect performance too much, though the engine once missed a fire whilst doing this.
The engine was professionally rebuilt in 1994 and converted to run on unleaded fuel.
Am I just being paranoid or could this be knocking/pinging?
Thanks alot,
Conor
PostPosted: Fri Nov 09, 2007 2:30 am
could be...
does the sound "rings" a little, like a muted bell? happens at all throttle positions or just if you WOT it? Have you tried disconnecting the vac pod?
maybe it just ticks under load, I had an engine that did that. Does it overheats when you WOT it and does this sound?
Juan Ignacio Caino
PostPosted: Fri Nov 09, 2007 2:50 am
Hello,
The best way I can think of describing the sound is like hitting a small piece of tin foil with a piece of wire.
The temperature does tend to rise a little if I am on a longish climb at reasonably high speed (60ish).
I have not disconnected the vac yet, I don't want to do the test till I have my new fuel pump and new oil in (Amazing, ordered the pump wednesday night from RockAuto and it was here in the UK friday morning, all for the price of ten beers!).
Thanks alot,
Conor
PostPosted: Fri Nov 09, 2007 3:02 am
In answer to throttle positions, it does happen more at more open throttle settings, but I don't think it is at just WOT.
PostPosted: Fri Nov 09, 2007 4:39 am
It could be "pinging", or it could be a small exhaust leak. You could try retarding the timing about 5 degrees, and see if there is any change in the sound. If it goes away, it is pinging. If it is still there, might be the exhaust leak, from a gasket or a crack in the manifold.
PostPosted: Fri Nov 09, 2007 8:32 am
rhythmical or random? *pfffft**pfffft**pfffft**pfffft* and so on may be an exhaust leak *ringllll**ringl**ringglglglgglglg**ringly-a-doo* is pinging. :lol:
when backing up timing, do it a little at a time because 5BTDC or more does have an effect on exhaust sound and might fool you.
also, yoiu can check on your mech advance springs... maybe one's loose or broken and it's overadvancing when accelerating past certain RPM range.
Juan Ignacio Caino
PostPosted: Fri Nov 09, 2007 8:34 am
I recommend you buy the three books described in this thread. They will greatly accelerate your knowledge and understanding of American car engineering and construction in general, and all the mechanical details of your car in particular. The other responses to your query cover the two most likely possibilities (pinking and/or blowing exhaust manifold gasket). If you require a replacement manifold gasket set, it is very much worth your while to get the good gaskets for the manifolds-to-head and intake-to-exhaust junctions.
PostPosted: Fri Nov 09, 2007 9:46 am
May I suggest you look carefully at the exhaust manifold for cracks - I had the same experience, and when I took off the exhaust manifold it fell cleanly into two pieces (think it broke between cylinders 2 & 3). Considering it had cracked all the way through, I was surprised it didn't sound louder than a noticable ticking.
