| Slant Six Forum https://www.slantsix.org/forum/ |
| intsalling freeze plugs???????? Help https://www.slantsix.org/forum/viewtopic.php?t=25724 |
| Author: | stolan83 [ Tue Nov 06, 2007 5:59 pm ] |
| Post subject: | intsalling freeze plugs???????? Help |
are there any tricks to installing freeze plugs |
| Author: | Fopar [ Tue Nov 06, 2007 6:46 pm ] |
I have just used a large diameter socket that will fit into the recess of the casting plug , put a little sealant gasket cement not RTV, then tap with a hammer against the socket til the plug is flush. |
| Author: | Custom Coupe [ Wed Nov 07, 2007 3:52 am ] |
I replaced the freeze plugs in my engine in 2006.They're much easier to get at with the manifolds off. I used the gasket shellac and I still ended up with leaks. Very small leaks, I hoped they might stop after a while, but after about 3000 kilometres I still have some that are leaking. The engine shop here locally uses blue loctite. I didn't want to take the manifolds back off to try again, I figured I'd just make them worse. |
