It is currently Tue May 12, 2026 8:44 pm
Post new topic  Reply to topic  [ 30 posts ]  Go to page 1 2 Next
 Post subject: Motor mounts
PostPosted: Wed Nov 07, 2007 12:31 pm
Any idea where I can purchase motor mounts for 63 dart GT (225/3.7L)
PostPosted: Wed Nov 07, 2007 1:21 pm
See this thread. Just got off the phone with Steve @ Imperial Services, who reports the first batch of urethane interlock-equipped '62-'66 A-body slant-6 engine mounts are being assembled and finished now, and will be ready for shipment around Thanksgiving. They will be costly, i.e., between $150 and $200 a pair, but they will be the last engine mounts you'll ever have to buy.
Or you can still sometimes find the 3rd-world garbage that needs replacement every couple years for around $15 apiece if you look hard enough...
PostPosted: Wed Nov 07, 2007 3:49 pm
www.motormountz.com
I have used them with no problems, although they are only about a year old. Not everyone can justify $150 for motor mounts.
PostPosted: Wed Nov 07, 2007 4:18 pm
Hi Charrlie,
I did get a pair from these guys, and I have had problems getting/keeping them tight enough. These buggers are always slipping on me. I will be moving to the urethane models shortly, probably with the new engine that I need to start building.
PostPosted: Thu Nov 08, 2007 6:54 am
Contributor
Can anyone give a first-person report on urethane mounts in any application? Is there a noticable increase in vibration transmitted to the frame?
PostPosted: Thu Nov 08, 2007 7:39 am
Hi Charrlie,
How are they slipping? Do the nuts come loose? I can't see how they could slip on the engine bracket. On the "K" frame the hole is slotted, and could slip if the nuts were loose.
PostPosted: Thu Nov 08, 2007 7:44 am
Yup, they are slipping on the k-frame. My K-frame is powder coated, which probably is part of the problem. I have tightened them as much as I can, even using a cheater bar. I am tempted to try a dab of epoxy to hold them to the K-frame.
PostPosted: Thu Nov 08, 2007 7:51 am
Do you have a large washer between the frame, and the nut? I haven't had a problem, and I just tighten with a 1/2 inch rachet
PostPosted: Thu Nov 08, 2007 8:27 am
Put a star washer under the nut, she want slip no more.
Jess
PostPosted: Thu Nov 08, 2007 7:54 pm
Try spreading some valve grinding compound between the parts that are slipping, then tighten as usual.
1964 Dart 225 1966 Valiant 225
1966 Dart 273 1966 Barracuda 273
1969 Dart 225
'64-170 engine '66-170 engine
(two) 198 crank/rod sets in custom-fitted wooden boxes
wooden motor scooter with hybrid-electric drive
PostPosted: Fri Nov 09, 2007 7:00 am
I do have big flat washers there. Any idea where you can find star washers that big?
Thanks,
PostPosted: Fri Nov 09, 2007 8:45 am
Contributor
Do a search for MS35333 and MS35335. They are internal and external tooth lock washers.
Suppliers will have a chart with dimensions so you can determine which dash number is needed to complete the part number.
PostPosted: Tue Nov 13, 2007 3:14 pm
google motermountz.com it is real dont know if spelling is right
if i cant fix it, it anit broke
PostPosted: Tue Nov 13, 2007 3:30 pm
motormountz.com is how that site is spelled. I have a philosophical objection to buying parts from companies who can't be bothered to spell easy words correctly. This together with the rest of the many spelling and grammar mistakes on their page make it look like they're a bunch of not-very-bright 3rd-graders.
I also have a philosophical objection to putting forth the time, muscle, and effort to install garbage-quality parts — especially safety-related parts — such as $7 engine mounts made in Armpittistan. :-(
PostPosted: Tue Nov 13, 2007 5:05 pm
Hell, half the post on this site have spelling problems. At least they have mounts available. The mounts I got from them are made in India. The last ones I got from NAPA were made in India. The ones from "the Paddock" also India. As near as I can see they are all from the same manufacturer, so why pay the higher prices, when they all seem to be the same. If there were beter mounts available, that would be a different story. As you pointed out, the better mounts have not been, and will not be available untill the end of November 2007. A $7.00 mount is better then no mount at all, or a broken mount.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 7 guests
