slant 6 engines
https://www.slantsix.org/forum/viewtopic.php?t=25909
Author:  RamSST [ Sun Nov 18, 2007 9:27 pm ]
Post subject:  slant 6 engines
Ok I'm looking for some slant 6 engines. and I found one that I can get for free from a 68 dodge truck now I'm wondering if this is the same as the ones in the cars?
Author:  68barracuda [ Sun Nov 18, 2007 10:00 pm ]
Hey and welcome.
Changes were incorporated 68 and onwards as far as the crank is concerned at the rear on all slants.
Truck slants as far as I understand, has shot peened cranks, double steel cam roller gear and chain setup, and some even had thicker cylinder walls - here in RSA anyways - our blocks were cast locally.
More heavy duty 8)
Author:  DusterIdiot [ Mon Nov 19, 2007 6:51 am ]
Post subject:  Not necessarily so in US...
If it's original it might have a shot peened crank... (so far I've taken apart a few truck motors from the 60's and one 70's industrial engine and no shot peened crank was installed...)
The one thing I do know is truck mills sometimes had lower compression ratios than their car counterparts (bigger combustion chambers)...
If just looking for a block to work over, stick to 1968-1976 for a forged crank and the bigger crank pocket.
Happy Hunting...
Author:  SlantSixDan [ Mon Nov 19, 2007 8:07 am ]
Post subject:  Re: Not necessarily so in US...
Interesting. Never seen any evidence of same. There were LC pistons primarily for export markets with low-quality gasoline, but year upon year there was only one cylinder head p/n and none of the truck engine specs in the Weertman material refer to extra-large combustion chambers. What year truck engines have you seen this on, and did you take note of head p/ns?
