| Slant Six Forum https://www.slantsix.org/forum/ |
| The insides of my junk https://www.slantsix.org/forum/viewtopic.php?t=26666 |
Page 1 of 2 |
| Author: | slantzilla [ Sun Jan 13, 2008 7:56 am ] |
| Post subject: | The insides of my junk |
Jeffrey tray installed for a '66 pan. ![]() Another: ![]() Stock rockers, nothin' fancy here. ![]() Amazing how fast you can go with stock stuff. ![]() |
| Author: | VDART [ Sun Jan 13, 2008 8:02 am ] |
thanks for the photos-- Can't wait for some more possum /bagel taunts!!! Lawrence |
| Author: | sandy in BC [ Sun Jan 13, 2008 8:47 am ] |
Amazing how stock that all looks.... Looks like progress Dennis! |
| Author: | slantzilla [ Sun Jan 13, 2008 9:05 am ] |
Thanks guys! Motor is back in the car. I am hoping to get my trans brake trans back in a couple weeks and get that in the car. Keith has the trans because Griner had an idea to make the servo for 2nd gear apply more holding force. The trans already ahs a Powerglide band installed as an experiment and that worked pretty well too. Got my 4.56 pig ready to go into the housing too. All I gotta do is finish installing the engine/trans/rear, install the Cal-Tracs, install the fuel cell and all the plumbing, and "refine" the wiring in the car. Oh yeah, and deliver the car to my buddy's shop to get the new headers built. Other than that it's ready to go. |
| Author: | Dart270 [ Sun Jan 13, 2008 12:33 pm ] |
Great work, Dennis. Hope I can see your car run sometime this year!! I need to get out in my garage too... Lou |
| Author: | Red [ Sun Jan 13, 2008 1:17 pm ] |
Do you spot-weld your rockers on the bottom between the rocker shaft sleeve and adjuster hole or just run 'em bone stock? |
| Author: | slantzilla [ Sun Jan 13, 2008 3:25 pm ] |
Quote: Do you spot-weld your rockers on the bottom between the rocker shaft sleeve and adjuster hole or just run 'em bone stock?
They get a minor amount of grinding for clearance on the retainer. No welding. Hope we can get together sometime this year too Lou. |
| Author: | elam [ Thu Jan 17, 2008 5:02 pm ] |
Hello Dennis and Lou it's been a long time. Good to see your keeping up the good fight. |
| Author: | Charrlie_S [ Thu Jan 17, 2008 5:47 pm ] |
Quote: Hello Dennis and Lou it's been a long time. Good to see your keeping up the good fight.
Elam, good to see your still alive, and kicking. How have you been? Are you back into the slanted world?
| Author: | Dart270 [ Fri Jan 18, 2008 5:30 am ] |
Elam! Good to see you on the site. Hope all is going great in your beautiful corner of KY. Let us know what you're up to. Yep, projects are ongoing. My Valiant project should be stompin' the road courses again this Spring and hopefully running 13 sec 1/4 miles... 64 Dart body is finally fixed. Lou |
| Author: | slantzilla [ Fri Jan 18, 2008 5:45 am ] |
Ditto on the good to see you Mike. What kind of projects you got going? |
| Author: | Aggressive Ted [ Sat Jan 19, 2008 11:39 am ] |
Slantzilla, What compression ratio and cam do you have in this build? |
| Author: | elam [ Sat Jan 19, 2008 12:14 pm ] |
Hello Charlie, Lou and Dennis. Kentucky is still good I have been farming some playing with the horses Old Rooster is almost 28 now. I built a 30 chevy roadster pickup put a slant in it a short time then put in a 350 chevy and sold it. I am about to finish a 1/3 size 23 T roadster for my little neices to play with. It is really cool I used a twin cylinder brigges engine. Built my own tube front end with radius rods a big hurst shifter, a beer keg for a gas tank. Good to here from youall. A got a slant out the other day thinking about a rail job I have been building my own frames lately. I really love to weld so why not, the little T will be done very soon so I need something to weld on. |
| Author: | slantzilla [ Sat Jan 19, 2008 3:15 pm ] |
Quote: Slantzilla,
Compression is a touch under 11-1 according to Mike J.What compression ratio and cam do you have in this build? Camshaft is a 20+ year old Clifford that I bought used from Mike for $50 w/lifters. .558" net lift and 300* advertised duration. My new junk will have custom Ross 9.5-1 nitrous pistons for 6.7" rods and a Comp Cams nitrous cam. Maybe Mike will give me the specs on the cam when it gets here, maybe he won't. New junk will be a complete bottle baby, probably never run on muscle alone. |
| Author: | runvs_826 [ Sat Jan 19, 2008 3:51 pm ] |
Can't wait to see it when your done! Really looking forward to seeing what this engine can do on NA sometime. Thought the bottle out to be fun, hopefully will start to be able to race you guys this next season. Keep up the good fight! |
| Page 1 of 2 | All times are UTC-08:00 |
