| Slant Six Forum https://www.slantsix.org/forum/ |
| Pre-'65 1bbl. air cleaner base https://www.slantsix.org/forum/viewtopic.php?t=2761 |
| Author: | V. Tedeschi [ Sat Oct 13, 2001 4:12 pm ] |
| Post subject: | Pre-'65 1bbl. air cleaner base |
I am looking for a '64 or earlier air cleaner base for my 1bbl. air cleaner. These have a smaller overall diameter than the later ones. Also, I have misplaced the large harmonic balancer bolt during the engine rebuild of my '67 225 SL6, and would like know how to replace it (and/or the particulars on its dimensions, washer?). vmted@mac.com |
| Author: | dschumers [ Sat Oct 13, 2001 4:30 pm ] |
| Post subject: | Re: Pre-'65 1bbl. air cleaner base |
: I am looking for a '64 or earlier air cleaner : base for my 1bbl. air cleaner. These have a : smaller overall diameter than the later : ones. Also, I have misplaced the large : harmonic balancer bolt during the engine : rebuild of my '67 225 SL6, and would like : know how to replace it (and/or the : particulars on its dimensions, washer?). The bolt should be a 3/4" fine thread by about 1" long. None of the motors I have even had one in it, but I always put one in. Dennis slantzilla@excite.com |
| Author: | Doctor Dodge (Doug Dutra) [ Sun Oct 14, 2001 9:09 am ] |
: I am looking for a '64 or earlier air cleaner : base for my 1bbl. air cleaner. These have a : smaller overall diameter than the later : ones. Also, I have misplaced the large : harmonic balancer bolt during the engine : rebuild of my '67 225 SL6, and would like : know how to replace it (and/or the : particulars on its dimensions, washer?). I have a few of these early air cleaners, I will drop you a email. Using one of these early bases with the later top is a cool airflow trick, really opens-up the access to the filter eliment, same as flipping-over the top cover on the later air cleaners. ( I am not sure if the engine really runs all that much better but it sure does *sound* like it is, the intake roars like you popped-open the secondaies on a Thermoquad) As for the damper bolt, how can you loose something that was never there?? ( the damper is a "press fit", the factory never ysed a bolt) Grab one off a BB Mopar or better yet, buy one at the hardware store. Always check to be sure the added bolt head / washer thickness clears the fan blades or you will be in for a rude surprise when you fire it up. DD |
| Author: | Craig [ Sun Oct 14, 2001 9:22 pm ] |
There are some slant 6 engines that came with a damper bolt installed from the factory. Usually with manual transmission or certian belt driven accessories. Somewhere I've seen info about that in a official Mopar publication I have here. cfield@ll.net |
| Author: | Doc [ Mon Oct 15, 2001 8:33 am ] |
| Post subject: | Re: SL6 Crank Bolt |
: There are some slant 6 engines that came with a : damper bolt installed from the factory. : Usually with manual transmission or certian : belt driven accessories. Somewhere I've seen : info about that in a official Mopar : publication I have here. Good catch, I was thinking early stuff, (64) If you could find that service info, that would be cool. I do remember seeing crank bolts on some of the post 76 cast crank engines, usually holding-on a big cast iron pulley. It would be great to figure-out what years / models this bolts can be found on. ( sounds like it's time for a trip to the junkyards) DD |
