Engine i.d.
https://www.slantsix.org/forum/viewtopic.php?t=2766
Author:  Mark Ellsworth [ Sun Oct 14, 2001 12:40 pm ]
Post subject:  Engine i.d.
I have a sixties model slant that came out of a '70 Demon. I was told it's a 225, but I want to know for sure. What casting #'s or whatever will show me what I have?
Thanks,
Mark
catfan@radiks.net
Author:  Brian [ Sun Oct 14, 2001 2:46 pm ]
Post subject:  Re: Engine i.d.
: I have a sixties model slant that came out of a
: '70 Demon. I was told it's a 225, but I want
: to know for sure. What casting #'s or
: whatever will show me what I have?
: Thanks,
: Mark
I had the same question on my 65 Barracuda now confirmed 225. I was told a simple way to tell if the engine is a 225 look at the small hose's at the top of the water pump that attach to the head if there 1 inch long its a 170 and if there 1.5 or longer its a 225. Hope this answers your question.
Brian
65 valiant 200 convertible V8
65 barracuda /6
bduffy@onemain.com
Author:  Mark Ellsworth [ Sun Oct 14, 2001 3:13 pm ]
Helps! :-) I hoping for a 198 so I can use the rods to build a stroker 225. I know it's an oldie' because of the spark plug tubes.
catfan@radiks.net
Author:  Doctor Dodge (Doug Dutra) [ Sun Oct 14, 2001 8:44 pm ]
: Helps! :-) I hoping for a 198 so I can use the
: rods to build a stroker 225. I know it's an
: oldie' because of the spark plug tubes.
The shorter bypass hose or the block's casting number will not tell you if it is a 198 or a 225.
It's best to look at the stamped-in ID number on the top of the block, behind the alternator bracket and under the #1 spark plug. The number will start-off "225" or "198" depending on what it is.
Author:  Mark [ Sun Oct 14, 2001 9:07 pm ]
Dr. Dodge to the rescue! It's a 225. How hard is it to find a good set of 198 rods, or a good 198 period?
: It's best to look at the stamped-in ID number
: on the top of the block, behind the
: alternator bracket and under the #1 spark
: plug. The number will start-off
: "225" or "198" depending
: on what it is.
: DD
catfan@radiks.net
Author:  Brian [ Mon Oct 15, 2001 8:30 pm ]
: Dr. Dodge to the rescue! It's a 225. How hard
: is it to find a good set of 198 rods, or a
: good 198 period?
My Engine hopefully is a 225 since the number that is supose to be stamped is gone due to some block re work in the past I guess...
I just went by the simple rule and hopefully its right for me. Since I just replaced bent push rods on the little beast... But it runs so smooth now...
bduffy@onemain.com
