| Slant Six Forum https://www.slantsix.org/forum/ |
| Valve Lash Settings for older engine? https://www.slantsix.org/forum/viewtopic.php?t=2786 |
| Author: | WhaleMstr [ Sat Oct 20, 2001 9:35 am ] |
| Post subject: | Valve Lash Settings for older engine? |
I adjusted/checked the valve settings on my 69 - 225 and they were off a little, according to what the "book" says to use. The book says .012 intake and .024 exhaust. That's what I tried to accomplish and I think I got them all close. Is this correct? Or should I use a different setting for a motor with at least 196,000 miles on it? I was thinking that if I got them too tight they might burn a few things or I would loose power? Thanks for any info, Talk at ya later, Dan gramma@dm-tech.net |
| Author: | Doctor Dodge (Doug Dutra) [ Sun Oct 21, 2001 10:26 am ] |
| Post subject: | Re: Valve Lash Settings for older engine? |
: I adjusted/checked the valve settings on my 69 : - 225 and they were off a little, according : to what the "book" says to use. : The book says .012 intake and .024 exhaust. : That's what I tried to accomplish and I think I : got them all close. : Is this correct? Or should I use a different : setting for a motor with at least 196,000 : miles on it? : I was thinking that if I got them too tight : they might burn a few things or I would : loose power? : Thanks for any info, : Talk at ya later, : Dan .012 & .024 is a bit on the loose side, factory cams set at .010 & .020 but I tend to run the exhaust on the loose side (.021 - .022) to be safe. If your .012 / .024 setting sounds OK (not any loud ticking sounds) then you may want to run it for a while, then recheck / re-set later. I do not think you would see any real performance difference between the two settings. Search the messages for "key word" valve adjustment (all) and review these posts for more info. DD |
