It is currently Sat Sep 19, 2026 4:25 pm
PostPosted: Thu May 01, 2008 8:54 am
It's only when I turn right and it comes from the steering wheel. I have a 70 Duster with a three gear autmatic with the shift lever on the tree. it sounds like it comes from somwhere around the lever or just under the horn switch.
Could it be a bearing or something. Not a noise when i turn left, and the wheel is smooth.
Also, if I turn fully to the left and then begin to turn right, the noise apears just after the wheels turn over to the right.
Anyone who's had this problem?
1970 Plymouth Duster
PostPosted: Thu May 01, 2008 9:44 am
Have you pulled the steering wheel recently? Like to replace an ignition switch or turn indicator return?
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Thu May 01, 2008 6:07 pm
bwhitejr
No. Not anything like that.
PostPosted: Fri May 02, 2008 8:59 am
I have the same noise, but both directions - only at lower speed and unlevel ground - yeah I know it sounds weird!
Have you checked the gap between the steering wheel and the column?
Sorry I dont have much of an answer, but atleast youre not alone!
IRIE...
