It is currently Thu May 07, 2026 6:34 am
 Post subject: timing marks???
PostPosted: Sat May 24, 2008 6:08 pm
okay, finally grabbed up a timing light.
64 valiant, 225
motors not exactly a show specimen.
where should i be looking for timing marks?
can't locate any obvious marks, maybe buried under gunk. hints on where to start?
 Post subject: Yep...
PostPosted: Sat May 24, 2008 6:23 pm
there will be grooves on the damper/lower pulley, and there should be a tab bolted to the timing cover on the driver's side of the engine with marks on it (10-0-10)... unless your slant is from another 'era' then the timing tab may be on the other side of the engine... start there first...
good luck
-D.idiot
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
