slant 6 engine size I.D.
https://www.slantsix.org/forum/viewtopic.php?t=35491
Page 1 of 1
Author:  SwissValiant64 [ Sun May 24, 2009 10:16 am ]
Post subject:  slant 6 engine size I.D.
How can one determine whether you have a 170 cu inch or a 225 cu inch? Is it encoded in the engine block number? If so, where is that located? Thanks,
Author:  Aggressive Ted [ Sun May 24, 2009 10:40 am ]
Post subject:  Engine numbers
Yes, it is stamped on the block above the coil. There is a ledge on the block deck that has a string of numbers. Clean up that area between the block and head and tell us what you find.
Take a look at this table from the articles section on the front page of this website
http://www.slantsix.org/articles/parts-matrix/jpg.htm
SL6 Dan also has the secret decoder ring.
Author:  SwissValiant64 [ Sun May 24, 2009 5:48 pm ]
Ted, thanks for the quick reply. It's a 170, which after reading up on other comments on the 170, I'm kinda psyched about. I just ordered a clutch kit and have the replacement 3-speed trans ready. I thought it odd there were no other engine serial numbers near the "170". Is that odd?
