It is currently Sat May 16, 2026 1:04 pm
 Post subject: pushrod installation
PostPosted: Sun May 24, 2009 12:21 pm
my 86 van is running like crap and i found out it has a broken push rod. its on the front cylinder; how do i put in a new one? and what would have made it brake? i just started to pull a hill and thats when it happened. the motor has 9500 miles on a rebuild but the rebuilders butchered the job as i stated on earlier posts about 2 years ago.
PostPosted: Sun May 24, 2009 2:16 pm
It could have been too loose and jamed.
PostPosted: Sun May 24, 2009 4:27 pm
do i compress that one spring and slide in the push rod or do i have to take off the rocker assembly
PostPosted: Sun May 24, 2009 5:44 pm
82truck,I remember,lets see thats a hydro motor right? If so yup pop the whole rocker off and change the P-rod.I'm wondering if a lifter didn't pump up/stick maybe wacked a valve? Don't think its to common for a hydro P-rod to be breaking like that.Could be just a junk piece that finally broke.Like Ted says coulda got loose if the lifter collapsed so check everything out while your in there.Good luck.
Users browsing this forum: No registered users and 15 guests
