It is currently Fri May 15, 2026 10:24 pm
 Post subject: Forward stut kit?
PostPosted: Sat May 23, 2009 6:48 pm
Whats your thoughts on Forward strut kits from Magnum Force. The kit ties the front firewall to the core support and beefs up the top of the shock tower. Will this kit help stiffen the front of the car? I will be welding in some subframe connectors and was wondering if it would be worth the money to install these at the same time. I plan to set the car up for the street and some hard cornering down the road.
 Post subject: Hard corners
PostPosted: Thu May 28, 2009 7:36 pm
Car Model: '63 Dart GT Convertible
If you want to do some hard cornering, check into back issues of Mopar Action. The "Green Brick" build was, and I guess still is, one of the baddest A- bombs on the road or track. At one point they achieved a 160mph up hill run at Watkins Glenn. To do that takes being able to come out of a corner good. Truely an A body inspiration.
ifyoubegintothinkyou'relosingcontrol...it'salreadygone
