It is currently Sat May 09, 2026 10:42 pm
 Post subject: Exhaust Gasket Help
PostPosted: Fri Sep 04, 2009 9:00 am
The gasket at the bottom of the exhaust manifold needs replacing about every 300 miles, as mine is completely burning out. Is a more robust gasket available anywhere?
PostPosted: Fri Sep 04, 2009 9:21 am
Yes,use the search function for Remflex gaskets and Aussie gaskets that will give you the links.
PostPosted: Fri Sep 04, 2009 9:37 am
Remflex ordered... thanks!
PostPosted: Fri Sep 04, 2009 11:14 am
