| Slant Six Forum https://www.slantsix.org/forum/ |
| very odd piston gouge ?! https://www.slantsix.org/forum/viewtopic.php?t=37001 |
| Author: | Volare4life [ Sun Sep 06, 2009 8:45 am ] |
| Post subject: | very odd piston gouge ?! |
Got a quick question once I dissassembled my '76 225 for a rebuild and got her all cleaned up and noticed a strange gouge (?) in the #2 piston so should I be worried ? I checked the valves, non of them are chipped of gouged and spin freely with springs removed.-Mike |
| Author: | Doctor Dodge [ Sun Sep 06, 2009 9:18 am ] |
Looks to me like the manufacturer added that "feature" when the top of the new piston was machined. I can hear the machinest now... "that wont hurt anything, it's good". DD |
| Author: | Wizard [ Sun Sep 06, 2009 9:57 am ] |
That one spiral gouge is typical of worn out automatic machining mechanism that failed to retract cutter correctly after facing the top of piston. Run it. Cheers, Wizard |
| Author: | slantzilla [ Sun Sep 06, 2009 1:07 pm ] |
It will add swirl to the mixture in the chamber resulting in better mileage and more horsepower. GM called it Vortec. |
| Author: | Volare4life [ Sun Sep 06, 2009 7:03 pm ] |
really zilla, WoW not lol, but how much deck is available on stock pistons ? Is it better to have glass smooth tops on the pistons or those "rings" that are machined ok to have ? -Mike |
| Author: | slantzilla [ Sun Sep 06, 2009 8:23 pm ] |
Actually the Vortec had the swirls cast into the intake runners. I would not worry about marks in the piston tops as long as long as they are not too deep. |
| Author: | Shazzam66 [ Sun Sep 06, 2009 8:35 pm ] |
maybe try to get another piston if your worried about it? I would. there is a perfectly good explaination why it has that mark on the top: aliens have visited your engine and are performing crop circles on the top of your pistons.... |
