| Slant Six Forum https://www.slantsix.org/forum/ |
| it dont hook up! https://www.slantsix.org/forum/viewtopic.php?t=39650 |
| Author: | theslantingsix [ Tue Mar 30, 2010 5:42 pm ] |
| Post subject: | it dont hook up! |
well ive got my slant all together after about a year and im about ready to fire her up but one problem the stock throttle linkage! i have converted to a holley 390 on an offenhouser intake and its driving me crazy couse i wanna get the car runnin so if yall 4bbl slant owners could help a guy out it would be apreciated very much thanks josh |
| Author: | darrt wells [ Tue Mar 30, 2010 7:16 pm ] |
Not sure of your actual question. But, if it helps at all, I have an offy intake with holley 4bbl carb, and stock throttle linkage. It will work if you fabricate a new bracket, and the carb is mounted with primaries facing the front of the engine. It works, but not ideal. If you are having length issues, a k-car cable can be made to work, with enough length to mount carb with primaries facing the valve cover. |
| Author: | ceej [ Tue Mar 30, 2010 7:34 pm ] |
There is a Holley adapter that allows full throttle operation. It bolts to the throttle lever. If your looking for a throttle cable bracket, some of the speed shops have things that can be improvised to work. They are generally made for V8 applications. I fabricated my own. Are you looking for tuning advice? 52 primaries, 56 Secondary, Purple spring, Orange cam, screw hole #2, 28 shooter, 10.5 PV. That's a start. CJ |
| Author: | theslantingsix [ Wed Mar 31, 2010 4:52 am ] |
Quote: Not sure of your actual question. But, if it helps at all, I have an offy intake with holley 4bbl carb, and stock throttle linkage. It will work if you fabricate a new bracket, and the carb is mounted with primaries facing the front of the engine. It works, but not ideal. If you are having length issues, a k-car cable can be made to work, with enough length to mount carb with primaries facing the valve cover.
sorry the question is how do i hook up my holley 390 to my gas pedel and have a bind free linkage?could ya post some detailed pics of of your set up? ide like to go the cheapist way possable what about a lokar linkge? would they have enything cut to fit? thanks ceej i wasnt looking for tuning advice, but that will help me after i get her running and start playing with the carb thanks |
| Author: | Mister Twister [ Wed Mar 31, 2010 5:52 am ] |
The lokar cable would fix you up!! We just mounted the 2bbl stock linkage to make the offy and 4bbl work!! |
| Author: | theslantingsix [ Wed Mar 31, 2010 1:22 pm ] |
is the lokar kit cut to fit or what? |
| Author: | Pierre [ Wed Mar 31, 2010 8:51 pm ] |
Yep it is. I used it on my clifford + 390cfm 8007 along with the lokar bracket that holds the gas and kickdown cable. |
