| Slant Six Forum https://www.slantsix.org/forum/ |
| Slant over heating https://www.slantsix.org/forum/viewtopic.php?t=39705 |
| Author: | PSI-VAL [ Sat Apr 03, 2010 9:49 pm ] |
| Post subject: | Slant over heating |
I have a 69 vf valiant slant 6 that i have turboed. problem is the intercooler sits in front of the radiator and the car is overheating from a cold start in about 20 minutes. also doesn't help being in australia with a pretty warm climate. Any suggestions to keep it cool? |
| Author: | Fopar [ Sat Apr 03, 2010 11:00 pm ] |
Anyway you could mount a longer/slender intercooler lower on the front end. Like lower than right in front of the radiator? |
| Author: | Reed [ Sat Apr 03, 2010 11:12 pm ] |
Mount an electric pusher fan in front of the intercooler? Run a bigger radiator? |
| Author: | SlantSixDan [ Sun Apr 04, 2010 6:55 am ] |
Welcome on the board. When you say the engine will overheat in about 20 minutes from a cold start, does that mean if you start it and just let it sit there idling (or drive it normally/moderately) it'll overheat? Or only if you're whalin' on it? |
