S6 - V8 swap with S6 manual trans
https://www.slantsix.org/forum/viewtopic.php?t=39753
Author:  dookdart [ Wed Apr 07, 2010 7:45 pm ]
Post subject:  S6 - V8 swap with S6 manual trans
Just curious; let say the S6 dies and untimely death.
Is it possible to install a SB (318) and maintain the S6 3 spd. columnn shift trans?????
Author:  Joshie225 [ Wed Apr 07, 2010 8:14 pm ]
Yes, but to keep your existing clutch you'll have to find a 273 bellhousing and 122 tooth V8 flywheel. If you use the more common 130 tooth flywheel and bellhousing you'll need a new clutch. You'll probably also need a V8 z-bar. And if you have an A903 you'll likely break it in short order.
Is this an A-body?
Author:  Doc [ Thu Apr 08, 2010 8:31 am ]
Year & model is important with this swap.
Other items that you may need include:
The correct exhaust manifolds & piping for the chassis.
Engine mount brackets for the chassis / K-frame.
Short throttle cable & possible peddle assembly.
Correct oil pan and possible dropped centerlink.
Water pump and pulleys for pass side hose entry.
