| Slant Six Forum https://www.slantsix.org/forum/ |
| pcv valve https://www.slantsix.org/forum/viewtopic.php?t=39760 |
| Author: | Tadams [ Thu Apr 08, 2010 9:36 am ] |
| Post subject: | pcv valve |
after checking the vacuum and finding it in the low normal I changed all of the hoses. the one that goes from the bottom of the carb to the pcv valve is loose at the pcv valve. is there a special hose or mine looks like fuel line. i'm sure i'm loosing vacuum there. i'm running 17 and hopefully this would make it higher. thanks for your help. |
| Author: | SlantSixDan [ Thu Apr 08, 2010 9:48 am ] |
Original hose is 11/32" inside diameter. That's a tough size to find; usually I wind up using 5/16" fuel hose. Don't use 3/8", which is a little too large. |
| Author: | Tadams [ Thu Apr 08, 2010 10:03 am ] |
thanks Dan, I feel like that may solve some of my problems. |
