| Slant Six Forum https://www.slantsix.org/forum/ |
| valve adjustment when cold? https://www.slantsix.org/forum/viewtopic.php?t=40827 |
| Author: | 65rbdodge [ Tue Jun 29, 2010 9:15 am ] |
| Post subject: | valve adjustment when cold? |
what are the clearences? |
| Author: | Fopar [ Tue Jun 29, 2010 9:45 am ] |
Stock cam or aftermarket ?? |
| Author: | 65rbdodge [ Tue Jun 29, 2010 11:58 am ] |
all stock |
| Author: | emsvitil [ Tue Jun 29, 2010 1:13 pm ] |
I use Intake .012 & Exhaust .024 |
| Author: | 70valiant [ Tue Jun 29, 2010 4:02 pm ] |
Do it right, start it up, get it warm. Shut it off, pop off the rocker cover. Restart, drop the rpms as much as you can and keep it running and adjust your rockers. Doing it right makes very little mess. |
| Author: | Sam Powell [ Tue Jun 29, 2010 7:16 pm ] |
Quote: Do it right, start it up, get it warm. Shut it off, pop off the rocker cover. Restart, drop the rpms as much as you can and keep it running and adjust your rockers. Doing it right makes very little mess.
I agree, but Ems figures are a good place to start on an engine rebuild.Sam |
| Author: | Rug_Trucker [ Sun Jul 04, 2010 7:08 pm ] |
I set mine to the hot specs while cold and leave it................. now donning fire suit |
| Author: | sandy in BC [ Sun Jul 04, 2010 8:12 pm ] |
no fire from me,......I sometimes warm it up....shut it off .....and do it static..... |
| Author: | rustyfords [ Mon Jul 05, 2010 5:58 am ] |
I recently did a running adjustment for the first time and will never go back to the other way. It gets a little oil on things but it's easily wiped up. |
| Author: | ceej [ Mon Jul 05, 2010 9:32 am ] |
Quote: I set mine to the hot specs while cold and leave it.................
Well I set mine to cold specs while hot. Nyah. now donning fire suit NOT! Cold right after bolting the engine back together, Emsvitil gives you a good starting point. Loose enough to fire up and idle, tight enough that the parts aren't flopping around. CJ |
| Author: | 63gtcv [ Mon Jul 05, 2010 4:54 pm ] |
| Post subject: | less mess |
One thing I do to have less mess is to take a couple minutes and remove the fan. Keeps the air down. I set mine on 12&24,hot (truck specs). |
| Author: | Charrlie_S [ Mon Jul 05, 2010 7:12 pm ] |
| Post subject: | Re: less mess |
Quote: I set mine on 12&24,hot (truck specs).
Where did you find that spec? I have never heard of that for a slant six.
