| Slant Six Forum https://www.slantsix.org/forum/ |
| crank question https://www.slantsix.org/forum/viewtopic.php?t=40868 |
| Author: | aaadave [ Fri Jul 02, 2010 7:37 pm ] |
| Post subject: | crank question |
i've got a 72 dart, 225, with a bad crankshaft. i found a slant out of an 83 d150 i thought about rebuilding and just set the 72 aside. but if i decide to rebuild the 72, does the steel crank have to have the right rods, or can you use cast crank rods with the steel. i'm sure there's at least one bad rod in her and dont know about availability. thanks, dave. |
| Author: | slantzilla [ Fri Jul 02, 2010 7:47 pm ] |
Cast and steel cranks and rods are not interchangeable. |
| Author: | aaadave [ Fri Jul 02, 2010 8:12 pm ] |
thanks for the reply. one more question. would the cast crank and rods work in the 72 block ? |
| Author: | Joshie225 [ Fri Jul 02, 2010 8:29 pm ] |
No, the crank has to go with it's block cast to cast and forged to forged. All the bearings on the cast crank are narrower which is why you can't swap around. |
| Author: | aaadave [ Fri Jul 02, 2010 9:06 pm ] |
thanks, dave. |
| Author: | 66aCUDA [ Sat Jul 03, 2010 5:38 am ] |
Dave Both types of rods are available new or used. The Cranks are both available reconditioned or used. Hope this helps, Frank |
