| Slant Six Forum https://www.slantsix.org/forum/ |
| Ball joint replacement grease cup needed https://www.slantsix.org/forum/viewtopic.php?t=41024 |
| Author: | wjajr [ Tue Jul 13, 2010 1:03 pm ] |
| Post subject: | Ball joint replacement grease cup needed |
My tubular upper control arm spit out its ball joint grease cup today after jacking the car to check flex plate bolt tightness. The damn thing split apart. I have seen replacement cups somewhere on the web, but can’t remember who carries them. Anyone out there know where I could get some? Bill |
| Author: | DusterIdiot [ Tue Jul 13, 2010 6:45 pm ] |
| Post subject: | Yep... |
If these are the rubber "covers" that hold the grease then you have a couple choices: Energy suspension makes poly ones in red or black and I have used them and aren't the best but aren't "thin" like the rubber ones. I think the rubber ones that I've seen on new ball joints/etc.. are norris-mcquay. good luck, -D.Idiot |
| Author: | ceej [ Tue Jul 13, 2010 7:44 pm ] |
I usually pick them up at NAPA or Carquest. The local places here stock them. CJ |
