| Slant Six Forum https://www.slantsix.org/forum/ |
| Copper spray https://www.slantsix.org/forum/viewtopic.php?t=41714 |
| Author: | hellion_locdogg [ Wed Sep 01, 2010 5:45 pm ] |
| Post subject: | Copper spray |
Should I use this on the new metal gasket I got? Most metal gaskets(motorcycle) I have dealt with have a film or sealer on them. Or they are layered steel, alum, steel. ,Cliff |
| Author: | hellion_locdogg [ Wed Sep 01, 2010 7:11 pm ] |
30 views and not one yay or nay huh? Any suggestion would be great. ,Cliff |
| Author: | Joshie225 [ Wed Sep 01, 2010 7:55 pm ] |
You have to use something on the shim head gasket and Permatex Copper Spray-A-Gasket is a fine choice. Just used it on the steel shim head gaskets for a good friend's 383 in his Coronet wagon. |
| Author: | Aggressive Ted [ Wed Sep 01, 2010 7:57 pm ] |
Not enough info to comment. No link to the which copper spray? No mention if this is a stock steel head gasket or some ones custom? or (which brand) composite metal gasket? |
| Author: | hellion_locdogg [ Wed Sep 01, 2010 8:09 pm ] |
It is a Mopar steel shim style head gasket not an MLS or custom job. I was refering to the Permatex copper spay... All I really needed to say is that it was a head gasket. ,Cliff |
| Author: | madmax/6 [ Wed Sep 01, 2010 9:17 pm ] |
NO,If you are running high compression,turbo,nitros you will get different answers.Spray it lightly if you are going bone stock. |
| Author: | Charrlie_S [ Wed Sep 01, 2010 9:27 pm ] |
The stock Mopar head gasket does need a sealer. The "copper coat" should be fine. |
| Author: | hellion_locdogg [ Wed Sep 01, 2010 10:38 pm ] |
Should have got it from "the horses mouth" to begin with. lol Thanks again... ,Cliff |
| Author: | Charrlie_S [ Thu Sep 02, 2010 4:17 am ] |
Quote: Should have got it from "the horses mouth" to begin with. lol
I guess that's better then being called the other end. Thanks again... ,Cliff |
