| Slant Six Forum https://www.slantsix.org/forum/ |
| brake pipe unions https://www.slantsix.org/forum/viewtopic.php?t=42197 |
| Author: | Tod [ Sat Oct 09, 2010 9:45 am ] |
| Post subject: | brake pipe unions |
There I can find the brake pipe unions for brake pipe from front right wheel disk 14' to braking governor. I dont mean rabber piep, I mean airon. |
| Author: | Tod [ Sat Oct 09, 2010 10:48 am ] |
And please help me with Wheel Bearings. That exactly diametr I nead fjr my Satellite'72 http://www.rockauto.com/catalog/x,carco ... ttype,1672 there are a lot of |
| Author: | 4speed [ Sat Oct 09, 2010 11:56 am ] |
We need more information. You have a 1972 Plymouth Satellite Wagon with a slant six engine. Which brakes do you have? Disc brakes or 4 wheel drum? 10 inch or 11 inch? Which wheel bearing are you looking for? Front or rear? Do you know which rear end you have? 8 1/4 inch? 8 3/4? 9 1/4?. We need to know to help |
| Author: | Tod [ Sat Oct 09, 2010 11:57 pm ] |
I'v got disc brakes in front, I need bearings for front wheels. I'v got this construction: http://cgi.ebay.com/ebaymotors/New-11-M ... ccessories NOT this, as like in the Dart usually I know: http://cgi.ebay.com/ebaymotors/STOPTECH ... 2c5589e38c And what 'bout diametr of brake pipe |
| Author: | Tod [ Sun Oct 10, 2010 11:41 am ] |
there are 2 kinds of front disk brakes, right? |
| Author: | 4speed [ Sun Oct 10, 2010 5:35 pm ] |
I do not know if there is two types of disc brakes or not but I will find out. The rubber part of the brake line is called a "brake hose" it is flexible for wheel movement. What you are calling "pipe" is called "brake tubing" or "steel brake line" and come in many different lengths. The brass parts that the brake tubing goes in (on the cars frame) are called "tees" were three brake lines come together. If you are only tying two brake line together it is called a "coupler" or a "union". As far as size I think (some one please look it up) the brake line is 3/16 (inch) diameter and what ever length you need. One more question-do you have power brakes? |
| Author: | Tod [ Mon Oct 11, 2010 1:04 am ] |
Please, some one. send me a brake disk, I'm very need it! Help me. It's too expensive to buy from e-bay or something, cos it very havy. |
| Author: | Tod [ Thu Oct 14, 2010 8:55 am ] |
That screw thread on brake feeting? 3/8? It connect brake tubing and steel brake line. ![]() "this" ob picture |
