It is currently Fri Jul 17, 2026 5:28 am
PostPosted: Wed Nov 21, 2007 10:10 am
http://www.moby302.co.za/ :D
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Wed Nov 21, 2007 10:44 am
Definitely some interesting things there. I had no idea Chrysler built any A-body station wagons after 1966:
http://www.moby302.co.za/brochures/1970 ... afari.html
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Wed Nov 21, 2007 11:03 am
Yeah, Valiant station wagons (A-bodies, all of them) were built in Australia right through to the end in 1981. These Australian-built wagons were the ones sold in South Africa. Some of the ones sold in South Africa through 1970 got US Dart or Valiant front sheetmetal to match the US-body sedans in the South African model lineup.
Overview of the Australian Valiant wagons post '66:
Here's a '67-'68 VE model:
The '68-'70 VF model used the same body shell, but had a new grille treatment (very much like the US '69 Chevrolet), front park/turn lamps moved to the fender tops(!), and the tail/brake/turn lamps and related sheetmetal at the back were revised. Here's a VF sedan showing the new front end styling:
The '70-'71 VG model was the same as the VF except it had a new grille and new rectangular headlamps (and the new Hemi-6 engine, which was not installed on cars sold outside the Australian market...export 6-cylinder cars got the Slant-6).
The VH model, released in '71, was the all-new body shell that was used on all Australian-built Valiants through to '81. Headlamp, taillamp, grille, and trim styling was twiddled and tweaked over the decade, but that's it. Here's an '81 CM station wagon:
PostPosted: Wed Nov 21, 2007 11:20 am
And here is my 78 CL REGAL SE 318 - known over here as a Chrysler SE
A REALY fancy Valiant
Regards,
Fanie Gerber
PostPosted: Wed Nov 21, 2007 11:27 am
...and here's a quick paste-together of the two facing pages in that '70 South African Valiant brochure. It's not perfect, because the scans aren't perfect, but it gives a fairly good idea of what a '70 A-body wagon with '70 Dart front sheetmetal looks like:
PostPosted: Wed Nov 21, 2007 11:34 am
It is so interessting to see al the body shells that was known as valiants - and the Styling line from the original R through to the last CM and apparently to soem sources the new Chrysler 300 owe it s looks to these specifi two models - the family lines is quite clear around the front - crease in the bonnet, twin headlights, Grille shape, Bonnet shape
Nuff said 8) 8) 8)
Regards,
Fanie Gerber
PostPosted: Thu Nov 22, 2007 7:25 pm
That maroon wagon looks like it has A body Cuda tailights! :D
PostPosted: Thu Nov 22, 2007 8:32 pm
The Australian '67-'68 VE-model Valiant sedans and wagons did have taillamps very similar to the US Barracuda. Not the same, but very similar.
PostPosted: Sun Feb 20, 2011 12:12 pm
Interesting model.. number produced in this model ?? :roll:
http://www.hotrodnisse.n.nu/
[img]http://gaz_v8.users.photofile.ru/photo/gaz_v8/96085690/xlarge/122172586.jpg[/img]
PostPosted: Sun Feb 20, 2011 1:43 pm
Some interesting info re all the Australian models on this SITE
Use the "please select" box near the page top to check out the other years.
regards,Rod :D
PostPosted: Sun Feb 20, 2011 11:22 pm
regards,Rod :D
Thanks. :D
Users browsing this forum: ric325v63 and 1 guest
