| Slant Six Forum https://www.slantsix.org/forum/ |
| windage tray in a truck - rear sump pan https://www.slantsix.org/forum/viewtopic.php?t=43738 |
| Author: | DadTruck [ Sun Feb 20, 2011 7:02 pm ] |
| Post subject: | windage tray in a truck - rear sump pan |
spent some time this past weekend messing with an 87 D-150 slant that I pulled from the local pull-a-part,, wanted to see if it was useable core for a future build or if the motor was the reason the truck was where it was,,, looks like the motor is OK,, In the process of checking it out, I set on it a nos mopar windage tray,,, looks to fit on it fine,, posting this as some time ago I spoke with M Jefferies on using one of his windage trays on a D-150 and he did not think it would fit due to the oil pick up going to the rear. Likely he was being a good dude , and not wanting to sell something that would be a problem,,well it looks like the oil pick up on this rear sump would not be an issue. http://www.flickr.com/photos/13718356@N ... 973529507/ |
| Author: | Greg Ondayko [ Sun Feb 20, 2011 7:12 pm ] |
That NOS Windage tray has a larger cutout for the pickup tube than a jeffrey tray. I am sure with a little trimming the jeffery tray would work fine as well. Good Luck with it John! Greg |
