It is currently Thu Nov 26, 2026 8:20 am
 Post subject: Steering Wheel
PostPosted: Tue Mar 08, 2011 6:30 am
Has anyone ever refurbished a steering wheel?. Mine has a number of cracks and I was thinking of using either bondo or epoxy, sanding and painting. Is there a company that does this in case I happen to suck at it..Mark..for a 64 Valiant btw
If only I had the time to do what I want to do instead of what I have to do!
 Post subject: Steering Wheel Repair
PostPosted: Tue Mar 08, 2011 7:07 am
I removed the steering wheel, bought a two-part epoxy called "PC7" from Ace Hardware, filled in the cracks and other blemishes, and painted the wheel. It came out very nice! Advice: Fill with the PC7 gradually instead of putting a glob in each crack. You will end up sanding your work, so keep that in mind when filling bad spots. You will be pleased with your results.
PostPosted: Tue Mar 08, 2011 8:20 am
Thanks Goodman, I will try as well. Not only is my steering wheel cracked, my hands turn black after driving (because the paint wore off) =(
~Less think, more do
PostPosted: Tue Mar 08, 2011 8:59 am
POR-15 makes a steering wheel restoration kit, as do other manufactures. This kit is rather expensive, and duplicates several items we often have in the shop. However there is a tutorial at this web page that may be helpful in doing your own thing.
PostPosted: Tue Mar 08, 2011 9:03 am
The POR-15 people sell a kit to fix steering wheels; I've not tried it, but it looks like their epoxy putty. I've been pleased with their other products. I used vinyl (Krylon brand? can't say for sure) paint on our '75 Duster wheel; it held up much longer than I would have expected, but did start to wear off. If you do that, paint it outside and let it dry a week outside (it has a strong smell).
 Post subject: steering wheel
PostPosted: Tue Mar 08, 2011 9:12 am
Thanks guys. Doesn't sound too tough. I wonder if an epoxy paint would work well and have a longer life?
Users browsing this forum: Ahrefs [Bot] and 5 guests
