It is currently Thu Jun 25, 2026 5:21 am
 Post subject: Door hinge roller
PostPosted: Tue Mar 22, 2011 4:09 am
Does anyone know where you can buy the door hinge roller for a 65 valiant? And the seal? Mine are in pretty rough shape.
Thanks,
Rick
PostPosted: Tue Mar 22, 2011 4:55 am
Hello Rick,
All the various bits for the hinges are available here in Australia. See HERE
Hope this helps.
regards,Rod :D
 Post subject: Thanks
PostPosted: Tue Mar 22, 2011 1:39 pm
Thanks, Anyone know if we got them here in the states?
Rick
PostPosted: Tue Mar 22, 2011 1:56 pm
I have a box-full of decent used ones... (right side assemblies are not as worn)
 Post subject: Pm
PostPosted: Tue Mar 22, 2011 6:03 pm
PM sent doc
PostPosted: Tue Mar 29, 2011 6:54 am
Hi there,
Any of the things you're considering might work for a while or partially, but considering the damage that can happen if a garage door comes apart in the raised position I'd suggest calling a repairman.
The good news is that unless you get all fancy the actual door doesn't cost a whole lot - it's the motor and the rest of it that are the big expense. The bad news is that you're probably not going to be able to replace just one panel and have it look decent.
Thanks and regards,
- Esiquil Lara.
Esiquil Lara
PostPosted: Tue Mar 29, 2011 7:01 am
Super Six Conversion Stromberg
 Post subject: ??
PostPosted: Tue Mar 29, 2011 1:32 pm
:? :? I am talking about a car door not a garage door.
Rick
