It is currently Mon May 25, 2026 7:12 am
 Post subject: Header paint?
PostPosted: Mon Jan 23, 2012 6:15 pm
What does everyone prefer? Beside ceramic coating :shock: I dont have that kind of money. Im looking into VHT header paint,but I cant find a primer for it. Does VHT not need a primer?
PostPosted: Mon Jan 23, 2012 6:39 pm
I use hi temp bbq paint ...VHT is good also.... no primer...will last longer if you paint inside also....do a couple just get it hot and cool down,will last a bit longer before burning off, and it will burn off in time
PostPosted: Mon Jan 23, 2012 6:41 pm
Thanks :D
PostPosted: Mon Jan 23, 2012 7:00 pm
unless you are going Jet-Hot don't waste your money, just buy some Krylon 1200.
1964 Dart GT
PostPosted: Mon Jan 23, 2012 10:31 pm
i have experience with the VHT flame proof paint. yes there is a primer, each can is like 10-11 bucks. i used it on my VW header. it holds up bitchen, especially for a rattle can.
prep is very important. make sure its very clean. then use the primer. you have to cure it, i used my bbq, since vw headers disassemble in 4 smaller pieces. you cure it 3 times at 3 different temperatures, then you do the same for the actual paint. just follow instructions
i painted my vw header about 6 years ago, it use to be black, but now is a kinda grayish, but isn't any bit of surface rust, and isn't flakey
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 4 guests
