| Slant Six Forum https://www.slantsix.org/forum/ |
| steel shim head gasket https://www.slantsix.org/forum/viewtopic.php?t=47689 |
| Author: | Valleyant [ Mon Jan 23, 2012 3:40 pm ] |
| Post subject: | steel shim head gasket |
I am getting ready to remove/rebuild the cylinder head on my 1972 225 slant six. Gonna mill the head a bit, do some bowl work and clean up the ports a bit. I'd like to use a steel shim head gasket when I mate the rebuilt head to my existing shortblock. Other than cleaning the deck surface and checking for flatness (what tolerances am I looking for?), what else needs to be done to successfully use the steel shim head gasket? I think an advantage of the shim gasket is not needing to remove as much material from the cylinder head to bump compression. |
| Author: | hantayo13 [ Mon Jan 23, 2012 4:16 pm ] |
charlie s has shim gaskets if you need...am sure others will advise also yes you right about not needing to take as much when using shim gasket |
| Author: | Valleyant [ Wed Jan 25, 2012 2:32 am ] |
Thanks Han, I know the head will be straight after the mill job.....gonna check the deck surface for warpage and will use the shim gasket if it is sufficiently flat....and thanks for the source, will give him a shout! |
| Author: | Rob Simmons [ Wed Jan 25, 2012 7:41 am ] |
And you'll have it back together and ready to race with us, right!? Come to the banquet next month too... It will get you all fired up for racin'! |
| Author: | Valleyant [ Wed Jan 25, 2012 9:06 am ] |
Hi Rob, Thats the idea.....would love to make more car events...Hard to find the time though. Very thankful for this great site/resource for sure. Love your enthusiasm! |
