It is currently Mon Nov 09, 2026 1:42 pm
PostPosted: Mon Jan 27, 2003 8:36 pm
On the Holley 1920, can the acc pump be replaced or fixed if not working? And if so, is this something purchased in carb rebuild kit? Thanks, I've no idea of the answer on this.
Tom
 Post subject: Holley 1920 Repair
PostPosted: Mon Jan 27, 2003 11:38 pm
The rebuild kit does have the new accelorator pump diaphram.
Check to see if the pump linkage is working, sometimes the plastic cam lever breaks and that can be fixed without opening the carb.
Users browsing this forum: Amazon [Bot] and 3 guests
