It is currently Mon Nov 09, 2026 7:18 am
PostPosted: Mon Feb 10, 2003 7:27 am
I just got a turbo/intercooler/manifold from an 88 T-bird Turbo Coupe for $150. I'm gonna run a blow-through system with a 2 or 4bbl carb, ported head, aftermarket cam, aftermarket intake. Anybody know of any good carb rebuilders that can build up a carb for me??? Any advice will be appreciated.
-Don
Forget the flowmasters...here come the good ol' GLASSPACKS!!!
PostPosted: Mon Feb 10, 2003 8:51 am
I would buy a new carb. from Summit, they start around $180.00
No matter what you start with, you will have to do some retunning to get it to work well on a Turbo Slant. With that in mind, you may as well start with a "known" new carb.
PostPosted: Tue Feb 11, 2003 7:36 am
I was thinking of startin with a new carb but I wasn't sure if 10-12lbs of boost will damage a stock performance carb. Thanks Doc...any more advice on turbo'ing a slant would help. Thanks again.
-Don
