| Slant Six Forum https://www.slantsix.org/forum/ |
| Under Coating Removal https://www.slantsix.org/forum/viewtopic.php?t=49343 |
| Author: | stonethk [ Wed Jul 18, 2012 6:29 pm ] |
| Post subject: | Under Coating Removal |
Tried everything else every which way..this is the best tool for the job. Here is a top of the line multi-tool, Bosch also make one thats cheaper. The blades are pricey, a used one with all the teeth broken off is the way to go. This bugger should shave at least 10-15 lbs of your ride.
| Author: | AussiePlymouths [ Sun Jul 22, 2012 4:24 am ] |
Great tip - thanks. |
| Author: | Sam Powell [ Sun Jul 22, 2012 7:26 am ] |
A heat gun makes things go MUCH faster. Just don't let the stuff fall on you. And keep the tip of the gun away from heat sensitive stuff, which would include your cloths and skin. Sam |
| Author: | hantayo13 [ Sun Jul 22, 2012 8:19 am ] |
yes looks like it be a time saver...have used heatgun and stiff puttyknive to remove ...heat helps alot ...be careful....once hot it becomes sticky like to your skin =bad burns |
