degreeing MP camshaft ??
https://www.slantsix.org/forum/viewtopic.php?t=4938
Author:  squeek360 [ Tue Feb 04, 2003 10:23 pm ]
Post subject:  degreeing MP camshaft ??
I finally got a degree wheel , so I'm going to be degreeing my cam on saturday , I initially have it set "straight up" based on the timing chain marks. Its a mopar performance cam with the following specs 268/268 duration , 56 overlap , .460/.460 lift with a recommeneded 106 centerline.
Does anyone have any experience with this cam ?? and would recommend any deviation from 106 ?? or should I just go by MP spec and set it up at 106 ?? thanx
Author:  Doctor Dodge [ Tue Feb 04, 2003 11:15 pm ]
For the street, I would advance that cam 4 degrees. Thats based on true "srtaight-up" so your first step will be to see if the marks on the gear set are accurate, then adjust from there.
Author:  squeek360 [ Thu Feb 06, 2003 6:29 am ]
thanx Doctor Dodge , so basically , if my marks are accurate , then my cam should be at 106 right now. so would this mean that ideally , I want this cam set up at 102 centerline ??
Author:  Doctor Dodge [ Thu Feb 06, 2003 9:05 pm ]
Yes, in your example, a 102 intake centerline = 4 degrees advance.
Here is a pretty good webpage on cam degreeing:
http://www.thedirtforum.com/degree.htm
Read-up and check everything twice, you should be fine.
Author:  slantzilla [ Thu Feb 06, 2003 9:28 pm ]
I have the same cam from Racer Brown. It is set at 105*, but it is still kinda lazy down low. If you are using an MP chain be sure to check it. Mine was marked almost 2 teeth retarded. :shock:
Author:  squeek360 [ Thu Feb 06, 2003 10:03 pm ]
thanx guys , I've never ran into a bad timing chain set that I'm aware of , of course I've only done a few. What would be the best way to verify the accuracy of the chain ?? would I for instance after I installed the cam , have made sure that the marks were lined up accurately with the number 1 cylinder at top dead center (compression stroke) and the valves on number one were in the "rock" position ?? or would there be a better way to verify this ??
Author:  slantzilla [ Fri Feb 07, 2003 3:49 am ]
I found mine when I tried to degree the cam. With the marks lined up, it was way retarded. :shock:
Author:  Dart270 [ Fri Feb 07, 2003 7:01 am ]
You sure that was the cam you were thinking about?? :roll:
Author:  rustycowl [ Fri Feb 07, 2003 8:06 am ]
Post subject:  split overlap
Lou got a zinger in there! :lol:
If you want to know the accuracy (of the marks on the timing chain), I think what you need to check with the marks lined up, is that you have split overlap, exactly, at TDC #1 (exhaust stroke).
Author:  slantzilla [ Fri Feb 07, 2003 6:27 pm ]
Methinks it may be time to release some information about Clay City last year. What do you think, "First round" Lou? :shock:
Author:  Dart270 [ Sun Feb 09, 2003 4:19 pm ]
You really think that nickname could stick? :o :oops:
Author:  slantzilla [ Sun Feb 09, 2003 7:54 pm ]
Never can tell! :shock:
Author:  1987_Ram-GT [ Sun Feb 09, 2003 8:09 pm ]
hmmm, need to know nickname for Lou ;)
i bet it could stick :D
Justin
