It is currently Tue Nov 10, 2026 12:40 am
 Post subject: Steel Shim Head Gaskets
PostPosted: Fri Mar 07, 2003 9:39 pm
Are the steel head gaskets still available for the slant?
PostPosted: Sat Mar 08, 2003 8:31 am
I do not know of any gasket suppliers who have a current listing for the .020 steel "shim type" gasket.
I have good luck finding them by calling the NOS gasket suppliers listed in Hemmings and on the web.
Be warned, only use a shim type gasket on freshly machined surfaces, both block and the cylinder head must have a clean / flat surface for these to seal.
If it is a used surface, stick with a composition gasket so you get a good seal.
PostPosted: Sat Mar 08, 2003 10:31 am
Is any one composit gasket thinner than the other? I.E. is Fel Pro thicker or thiner than ROL or any other major brand?
PostPosted: Sat Mar 08, 2003 11:52 am
As far as I know, the steel shim gasket is still available from Chrysler Corp. I bought some last fall, from Koller Dodge. Part number 02843182 cost was between $4.00-$5.00.
Users browsing this forum: Amazon [Bot] and 4 guests
