| Slant Six Forum https://www.slantsix.org/forum/ |
| water pump install? https://www.slantsix.org/forum/viewtopic.php?t=51407 |
| Author: | slant6 [ Thu Mar 14, 2013 2:53 pm ] |
| Post subject: | water pump install? |
Can I use black permatex # 16B, item # 81158, If not let me know the correct stuff, thanks, Dana |
| Author: | DusterIdiot [ Thu Mar 14, 2013 3:29 pm ] |
| Post subject: | Uh... |
Yes you could or orange/bronze RTV...but you should be able to install the pump strictly with the gaskets it came with if you cleaned the block mating surface. Are you reinstalling a used or previously installed pump? -D.Idiot p.s. when installing make sure to get the hose the head the right length and install first with hose clamps before installing the pump itself... |
| Author: | slant6 [ Thu Mar 14, 2013 3:42 pm ] |
| Post subject: | W Pump. |
D, My new wp does have the gaskets and I was going to put a little bit on each side. Am I right or wrong? |
| Author: | DusterIdiot [ Thu Mar 14, 2013 4:22 pm ] |
| Post subject: | No.. |
It's not needed, but if you are going to make them stick to keep them in place for a quick installation (less to 'juggle'), go for it, it won't hurt your install. -D.idiot |
| Author: | slant6 [ Thu Mar 14, 2013 4:42 pm ] |
Thank you |
| Author: | kielbasa [ Thu Mar 14, 2013 6:30 pm ] |
I used rtv on the block side because of corrosion pits. The rest was dry. |
| Author: | madmax/6 [ Fri Mar 15, 2013 9:03 pm ] |
I use grease,helps seal and makes removeing them later a breeze,no stuck gaskets to scrape.Guzzi Mark |
| Author: | Aggressive Ted [ Fri Mar 15, 2013 10:36 pm ] |
I prefer grease too. |
