| Slant Six Forum https://www.slantsix.org/forum/ |
| Lifting motor w/cherry picker? https://www.slantsix.org/forum/viewtopic.php?t=51430 |
| Author: | slant6 [ Sun Mar 17, 2013 8:48 am ] |
| Post subject: | Lifting motor w/cherry picker? |
For u pro's where is the best place on ea. Side of motor to raise motor in and out of vehicle? Thanks Dana |
| Author: | jhdeval [ Sun Mar 17, 2013 9:19 am ] |
With the head still in the car there is are 2 half inch bolt holes that you can attach to with either a leveler or a length of chain. Without that I would recommend a bolt in each corner of the head bolt locations meeting in the middle to lift from. |
| Author: | hantayo13 [ Mon Mar 18, 2013 5:34 am ] |
between the valvecover and manifold are 3/8 sae course thread holes, might have to remove some brackets to use |
| Author: | Doc [ Mon Mar 18, 2013 12:57 pm ] |
Use a single bolt and a "looped" strap, bolted onto the front bolt boss only, when pulling / installing the engine only. Run a strap between the front and back bolt bosses, when pulling / installing the engine with the transmission attached. DD
