What's a slant six weigh?
https://www.slantsix.org/forum/viewtopic.php?t=51499
Page 1 of 1
Author:  65CrewCabPW [ Sat Mar 23, 2013 2:37 pm ]
Post subject:  What's a slant six weigh?
I mean, dressed out with manifolds, carb, and with A904 attached?
Anyone know?
Author:  jhdeval [ Sat Mar 23, 2013 2:48 pm ]
Engine on its own is around 550. Around 75 pounds for the intake and exhaust manifold. I have not looked at the transmission weight.
Author:  DusterIdiot [ Sat Mar 23, 2013 6:40 pm ]
Post subject:  Depends...
It kind of depends on the version you are getting:
Forged Crank slant six 1 barrel may be 500-600 lbs (early cranks are heavier, but drool tube heads aren't as heavy as the peanut plug heads,
aluminum intake manifold, etc... cast cranks are lighter in may respects, got an aluminum block?)
I loaded a 1979 cast crank engine shod with the 1 barrel setup and a late A904 in the back of my truck and it didn't even flinch (the front gets 'light' if over 750 lbs...)
Check Doc's posts on throwing together an engine with all the light components.
Author:  65CrewCabPW [ Sat Mar 23, 2013 9:23 pm ]
THis would be 76 or older.
