| Slant Six Forum https://www.slantsix.org/forum/ |
| valve lash https://www.slantsix.org/forum/viewtopic.php?t=5171 |
| Author: | Guest [ Fri Mar 07, 2003 3:39 pm ] |
| Post subject: | valve lash |
I just rebuilt a 225 slant six and have a MP cam 0.460 lift 268 dur. It recommends .016 int .020 exh can i run the lash a little tighter or should I stick with the recommended spec |
| Author: | Doc [ Fri Mar 07, 2003 4:53 pm ] |
I tend to run the lash on the MP 268/.460 at .016 and .024 Try a few different settings to get the best mix of idle quality and noise control. Best to have at least 9 to 1 compression with this cam. DD |
