Steel Shim Head Gaskets
https://www.slantsix.org/forum/viewtopic.php?t=5174
Page 1 of 1
Author:  Eric W [ Fri Mar 07, 2003 9:39 pm ]
Post subject:  Steel Shim Head Gaskets
Are the steel head gaskets still available for the slant?
Author:  Doctor Dodge [ Sat Mar 08, 2003 8:31 am ]
I do not know of any gasket suppliers who have a current listing for the .020 steel "shim type" gasket.
I have good luck finding them by calling the NOS gasket suppliers listed in Hemmings and on the web.
Be warned, only use a shim type gasket on freshly machined surfaces, both block and the cylinder head must have a clean / flat surface for these to seal.
If it is a used surface, stick with a composition gasket so you get a good seal.
Author:  Eric W [ Sat Mar 08, 2003 10:31 am ]
Is any one composit gasket thinner than the other? I.E. is Fel Pro thicker or thiner than ROL or any other major brand?
Author:  Charrlie_S [ Sat Mar 08, 2003 11:52 am ]
As far as I know, the steel shim gasket is still available from Chrysler Corp. I bought some last fall, from Koller Dodge. Part number 02843182 cost was between $4.00-$5.00.
