V8 in 69 dart!??
https://www.slantsix.org/forum/viewtopic.php?t=52096
Page 1 of 2
Author:  Gjason89 [ Thu May 16, 2013 12:14 pm ]
Post subject:  V8 in 69 dart!??
Would a v8 84 360 long block with a 727 tranny fit in my 1969 dart that recently had a slant six? Help I got a good deal on the price n wonder if it will work:/
Author:  DusterIdiot [ Thu May 16, 2013 12:24 pm ]
Post subject:  Yes, but...
You will need:
Better torsion bars
Better front brakes if not disc equipped.
New rear axle
Conversion engine mounts to convert to the V-8 (or if doing the hard way, a V-8 K-member with 1967-1972 motor mounts).
Author:  Aggressive Ted [ Thu May 16, 2013 12:33 pm ]
and a shorter drive line...
Author:  DusterIdiot [ Thu May 16, 2013 12:39 pm ]
Post subject:  Lol...
Oh, and a new slip yoke for that as 727 is bigger than 904...
-D.idiot
Author:  Reed [ Thu May 16, 2013 12:53 pm ]
And a new radiator, and new exhaust, and possible engine wiring mods, and possibly different accessory brackets, and other greebly bits....
Author:  vynn3 [ Fri May 17, 2013 5:48 am ]
And a slant six site probably isn't the best place to ask about replacing a slant six with a V-8...
Author:  63Valiant [ Sun May 19, 2013 6:58 am ]
Post subject:  Re: Yes, but...
WHY would you do that? Is it that important to be like everyone else?
Author:  hantayo13 [ Sun May 19, 2013 7:09 am ]
WHY STOP with a small block....I know of a few darts with 383s and 440s in them also ...dont forget to add the frame connectors...or you will twist body
Author:  75valiant [ Mon May 20, 2013 9:21 am ]
well, this one certainly started off well...
Author:  Reed [ Mon May 20, 2013 9:43 am ]
These are are valid answers to the initial question. Swapping a v-8 in place of a slant six is more complex than it sounds, especially if you want the car to be reliable and safe to drive.
Author:  DusterIdiot [ Mon May 20, 2013 4:14 pm ]
Post subject:  Also...
Also the 360 even in 2 barrel format will provide about 1/2 the mileage the slant six did, so a $150 long block and tranny combo will be shelling out about 9-13 mpg on a regular basis...
So what's cheap now will not pay back in the long run...
:roll:
Author:  wjajr [ Mon May 20, 2013 6:05 pm ]
The just wondering department:
Why use last century’s technology? This is the V8 road I would take:
Just drop in a Gen III Hemi and drive train with all the electronic fix’ins, and get better fuel economy than 53 year old slant architecture is capable of, and tire roasting performance… Oh, and the complexity of this project will be exponentially several notches over an old 360 transplant… Or, for exceptional fuel sipping, light, powerful combo, dump in a Pentastar V6 with an 8 speed.
How do I know this, my 4200 pound 300C AWD gets 24 mpg on the interstate, my Dart’s best is 18.5 mpg at a tick over 3000 lb. The above same 2+ ton tank with a Pentastar in it runs into the 30 mpg range.
Author:  Gjason89 [ Mon May 20, 2013 6:13 pm ]
Reason being is I was going to fully rebuild my engine but came out my block had a little crack my the main barings so any parts needed everyone HAVE AT IT! 956 289 0575 engine was running before took apart for rebuild! Also have the 727 tranny auto I jst so happend to find a cheap 360 with a 927 transmission will I need I need a new drive shaft? How do I know how long?
Author:  DusterIdiot [ Mon May 20, 2013 6:46 pm ]
Post subject:  The uggghhhly late conversion...
This is the real killer is the late motor mounts are not like the older motor mounts, I think E-berg wrote an interesting article on it and some now has conversion mounts but again $$$...I also read same author's late hemi swap and although straight forward, lots of wire chasing is required.
That's and apples and oranges comparison...convert your slant to EFI and put an OD transmission behind it and then you can square up the comparison...given what Lou has done( and I'm sure there's more in there), both would be equal in mpg.
:lol:
Author:  Gjason89 [ Mon May 20, 2013 7:23 pm ]
Since my car is a 69 dart but the engine is a 84 360 when I get parts what year would I put dart 360 or the van 360 I'm being told my exhuast manifolds won't fit:/ how do I know what manifolds to get or will they fit smtng to do with the steering column:/??! ANYONE!
Page 1 of 2 All times are UTC-08:00
