It is currently Thu Jan 01, 2026 10:28 am
PostPosted: Wed May 15, 2013 4:21 pm
OK, so after reading about swapping a 390 cfm 4bbl on an Offenhauser intake for my '75 Slant 6, I realize most folks recommend a 2bbl on an otherwise stock motor (with less restrictive exhaust). I am considering going with an adapter for my Offy and mounting a Holley 2Bbl which originally was for '68 and '69 383s.
Any feedback?
Harry
1975 Plymouth Scamp 225/904/8.75
1968 Plymouth Road Runner 383/727/8.75
 Post subject: Bolt pattern wrong...
PostPosted: Wed May 15, 2013 4:35 pm
Holley 2210 or the later 2245 (and the 'big BBD') found on the big block will need a custom mount as it doesn't share the more common 2300 bolt pattern (found on Ford and the 6 pak mopars...), you would also need another adaptor if going back further to say a small block BBD or Holley 2280.
The big block holley will also be a bit rich in all respects, and can't be tuned like the stocker model holleys.
Just FYI before you get it all in hand and go "D'oH!"
PostPosted: Fri May 24, 2013 11:32 am
So what options do I have as far as using the Offy 4bbl intake with a 2 bbl carb? I see several differnt adaptor plates on ebay. None of these would work? I would rather not have to but a manifold if I can somehow use this one.
Harry
PostPosted: Fri May 24, 2013 12:01 pm
How about this piece?
http://www.ebay.com/itm/Mr-Gasket-2bbl- ... _234wt_647
Harry
 Post subject: Looks like...
PostPosted: Fri May 24, 2013 1:44 pm
The bolt patterns on it are for Holley 2300, and the inner slots might be "little BBD/Holley 2280"....
PostPosted: Fri May 24, 2013 6:35 pm
I ran an offenhauser with the holley#4412 500cfm 2bbl. That is a killer street combo..gave them rice mobiles a fit :lol:
Michael Glass. Mopar stuff and some rusty Mopar stuff!
1965 Dodge Dart with 66 Valiant front clip. Other stuff...
