It is currently Fri Jan 02, 2026 10:50 pm
 Post subject: Trans Kickdown
PostPosted: Sun May 26, 2013 8:39 pm
65 Barracuda Trans kickdown upgrading to super six.
So my question is if i can find the trans kickdown adjustment rod will I have to make any changes to my existing kickdown or can I just connect the rod to the same location the old rod was?
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Mon May 27, 2013 9:59 am
Anyone? I have a lead on the connection between the carb and kickdown but I don't want to waste money if I can not make it work.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Mon May 27, 2013 10:11 am
Is your current throttle assembly a rod style or a cable style? If you have a rod throttle assembly then you will need a totally different throttle cable and kickdown system.
PostPosted: Mon May 27, 2013 11:09 am
My current is a rod style. I am upgrading to the super six and have the floating pedal. I also have a cable kick down similar to lokar
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Mon May 27, 2013 12:23 pm
You will need to use the cable kickdown linkage.
PostPosted: Mon May 27, 2013 2:31 pm
Thats what I needed thank you Reed. I was hoping that it might make my life a bit easier.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
Users browsing this forum: Ahrefs [Bot] and 17 guests
