170 deck height?
https://www.slantsix.org/forum/viewtopic.php?t=5236
Author:  Matt Cramer [ Sat Mar 15, 2003 6:11 pm ]
Post subject:  170 deck height?
What is the crank centerline to deck height of a 170 block? After that import piston into slant six thread, I've been thinking of making a spreadsheet that will let me evaluate various combinations of pistons, rods, cranks, and blocks, along with various amounts of milling the head and deck, and I was missing that particular dimension.
Author:  slantzilla [ Sat Mar 15, 2003 9:40 pm ]
Don't know what the dimension is, but a 170 is a zero deck height moder anyway I believe. :shock:
Author:  Matt Cramer [ Mon Mar 17, 2003 7:45 pm ]
Post subject:  Thanks!
That should make it easy to calculate. Come to think of it, the MP Six Cylinder manual lists the piston-to-deck height as 0.040" down in the bore to zero. I'll start with the -0.040" and use that to estimate the block's dimensions.
Author:  Doctor Dodge [ Mon Mar 17, 2003 7:54 pm ]
It has been a long time since I built a stock stroke 170 but I think the crank centerline to deck is 9.540
Double check this dim., I don't find anything in my notes to back it up.
Author:  Matt Cramer [ Wed Mar 19, 2003 7:20 pm ]
Post subject:  Not quite...
I double checked that one, Doc. That's a bit too high as that would work out to the pistons sitting way too low in the cylinders. Perhaps you meant 9.054"?
