It is currently Mon Nov 09, 2026 10:27 pm
 Post subject: 170 deck height?
PostPosted: Sat Mar 15, 2003 6:11 pm
What is the crank centerline to deck height of a 170 block? After that import piston into slant six thread, I've been thinking of making a spreadsheet that will let me evaluate various combinations of pistons, rods, cranks, and blocks, along with various amounts of milling the head and deck, and I was missing that particular dimension.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sat Mar 15, 2003 9:40 pm
Don't know what the dimension is, but a 170 is a zero deck height moder anyway I believe. :shock:
 Post subject: Thanks!
PostPosted: Mon Mar 17, 2003 7:45 pm
That should make it easy to calculate. Come to think of it, the MP Six Cylinder manual lists the piston-to-deck height as 0.040" down in the bore to zero. I'll start with the -0.040" and use that to estimate the block's dimensions.
PostPosted: Mon Mar 17, 2003 7:54 pm
It has been a long time since I built a stock stroke 170 but I think the crank centerline to deck is 9.540
Double check this dim., I don't find anything in my notes to back it up.
 Post subject: Not quite...
PostPosted: Wed Mar 19, 2003 7:20 pm
I double checked that one, Doc. That's a bit too high as that would work out to the pistons sitting way too low in the cylinders. Perhaps you meant 9.054"?
Users browsing this forum: Amazon [Bot] and 8 guests
