| Slant Six Forum https://www.slantsix.org/forum/ |
| 68 dodge sportsman thanks https://www.slantsix.org/forum/viewtopic.php?t=5245 |
| Author: | pbrstreetgang [ Sun Mar 16, 2003 4:09 pm ] |
| Post subject: | 68 dodge sportsman thanks |
i installed the petronic igniton and routed the neg and pos wires to the coil and everything works well. i am amazed at what a diffrence from the points type ignition. next up electric cooling fan and a highoutpute alternator. any suggestions on were to get them for my van also im looking for a new radiator any advice will be greatly appreciated. |
| Author: | Pierre [ Sun Mar 16, 2003 6:42 pm ] |
| Post subject: | high output alternator |
How high do you want to go? I got a powermaster 200a one (model 8-47539) supposedly that was a drop in fit but it wasn't, had to make a few simple brackets. It came with a tag that had actual test results on it, at 2000 rpm alternator spindle speed, output was like 135A and at 6000 rpm it was like 235A. Hookup was simple, I just unplugged the regulator then ran a 4awg battery cable from alternator to positive battery terminal. |
