no spark from coil what is the first thing to look for????
https://www.slantsix.org/forum/viewtopic.php?t=5289
Page 1 of 1
Author:  Xsnail [ Fri Mar 21, 2003 12:32 pm ]
Post subject:  no spark from coil what is the first thing to look for????
Dist. is back in everything seems right there. But now I am not getting spark from the coil. Would the coil be the likely culprit or that other electric thing????
Author:  Mike Keller [ Fri Mar 28, 2003 7:02 am ]
If you have an electronic ignition, it could be the white ballast resistor. It acts like a dead coil.
Author:  Super6 [ Fri Mar 28, 2003 10:26 am ]
also if electronic, check the magnetic pickup gap in the dist with a brss feeler gauge. Should be .008". If the gap is too large--no spark (ask how i know :roll: )
-Aaron
Author:  Pierre [ Fri Mar 28, 2003 12:04 pm ]
Or the module itself if electronic
Author:  Xsnail [ Fri Mar 28, 2003 5:01 pm ]
Got it going!!!
Now i just have to get the old gas out of it.
Thanks for the help on all the dumb questions.
Author:  '74 Sport [ Sun Mar 30, 2003 10:45 pm ]
Xsnail,
What did you have to do to get it going?
Just wondering in case I have the same problem later.
Jerry
Author:  Guest [ Mon Mar 31, 2003 5:45 pm ]
Ugg. do I have too? It was kind of dumb.
The fusable link had burned. But it did not totaly separate or noticeably go bad. When I touched it the insulation came off very easily with only a few strands of wire still intact.
