2 barrel intake linkage
https://www.slantsix.org/forum/viewtopic.php?t=5290
Page 1 of 1
Author:  valdar [ Fri Mar 21, 2003 1:40 pm ]
Post subject:  2 barrel intake linkage
I have a 65 dart 225 automatic. I just picked up a super six set-up from a 78 dodge aspen i got it with all the linkage. I was wondering if anybody had made a similar swap and how to set up the linkage since the styles are different or is this a custom job. if it is custom then is there a method to follow for the kickdown linkage adjustment and or configuration. any help would be great thanks. :?: :?: :?: :?: :?: :?:
Author:  NCDart [ Fri Mar 21, 2003 2:55 pm ]
I'm about to do the same on my 65 dart. I've been told to use the gas pedal from the donor car also. It's a hanging type of pedal, and this swap will make it much easier to do. Hopefully you grabed the gas pedal also. Perhaps someone will elaborate more on this topic.
