crank?
https://www.slantsix.org/forum/viewtopic.php?t=5309
Author:  slanted attitude [ Sun Mar 23, 2003 1:54 pm ]
Post subject:  crank?
What size pilot (fly wheel centering hub)does the 68 225 have?I just realized that someone changed the engine in my 61 Val to a 68 and was thinkin that this might be a good thing as im planning on changing to a 5-spd and that the bigger pilot might help as far as selection of flyywheels go. Also ,Dart 270, what did you do for a pilot bushing for your conversion? Thanks all.
Author:  Doctor Dodge [ Sun Mar 23, 2003 8:35 pm ]
68 was the first year for the large pilot crank, you will need to get in there and measure to know for sure because all cranks and blocks interchange / swap-over, 1960-75
Who knows what is really in there at this point.
Author:  Dart270 [ Mon Mar 24, 2003 7:14 am ]
I believe the hole is 1.815", but you should measure yours as Doc says. I made a cylindrical collar out of steel and pressed an '85 (80s, early 90s) Mustang roller pilot bearing into it (parts store $15), then pressed that unit into the crank hub hole.
Author:  slanted attitude [ Wed Mar 26, 2003 3:21 pm ]
Thanks for the info Lou.
