It is currently Tue Nov 10, 2026 11:08 am
 Post subject: Electronic Ignition
PostPosted: Tue Mar 25, 2003 5:17 pm
Chrysler no longer has the electronic ignition conversion for the slant. Where do I go from here. Finding a distributor is no problem or the ecu, but which balast resistor do I need and where can I find a wiring diagram to wire it properly?
Thanks,
C-dog
go fast, turn left, don't screw up.
WWW.Mopardropheadcoupe.com
 Post subject: diagram
PostPosted: Tue Mar 25, 2003 5:56 pm
On the main page of this site click the articles link, there is a picture of the proper wiring diagrams. The ballast can be bought from your local autoparts store or a junkyard.
PostPosted: Tue Mar 25, 2003 7:54 pm
Pierre,
Thanks, I am such a dork.....I knew that. Hello Mcfly.........
PostPosted: Tue Mar 25, 2003 8:21 pm
Does anyone know what kind of ignition was in a 87 dodge ram /6 truck? Is it the same electronic ignition as in the 73+ cars, the same parts?
PostPosted: Tue Mar 25, 2003 10:48 pm
Both the electronic ignition control and the voltage regulator on my '74 Dart Sport had some kind of sticky goo running down the inner fender. Should I replace them with similar components and hook everything back the same way, or should I consider going with some currently available ignition system? Any recommendations on which one?
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot] and 3 guests
